Old Mar 20, 2008 | 04:27 AM
Steve Hellums's Avatar
Steve Hellums
Default Re: What the HECK is the camber angle?
Originally Posted by SRTpowa
any pics? My Eibachs should be here friday. I also just picked up my new wheels and tires and had to go with a 275/30/19 in the rear. I was thinking about ordering the thinnest rear spring pads first and see how it sits with the smaller tires.
Here's a link to my install, I had a four wheel anignment done afterwards and everything was right on the money when they were done. I have the same problem Waldig had, to low in the front & not low enough in the back. I took care of the back by putting on some 285's, I used some 1/4" rubber to put on top of the spring cup in front, but I think the top of the spring cup has dented it's way into the rubber. The top of the cup is a circle less than a 1/4" thick, it looks about like the top of a heavy duty coffee cup. They make different thicknesss of spring cups and I'm planning on getting a thicker set for the front.
https://www.crossfireforum.org/forum...ghlight=camber
