wierd this car hardly even uses the rear brakes, I seriously doubt you need new rear rotors if your under 60k miles.
try changing the brake pads, might get rid of the squeek.
Originally Posted by Kurts
Hey folks!
Took the SRT in for some warranty work, odds & ends, but one reason was for an annoying squeak coming from the right rear wheel. The dealership said that the rotor is pretty pitted with rust & needs to be replaced SO how about some advice?
Obviously, the stock rotors would work just fine but what else have you folks used? Any suggestions? Since I don't have an unlimited budget 'coolness' would rate low in any decisions though I've got to admit those slotted rotors do look cool!
Regardless of the rotors, Rotex Gold's will be used.
