Originally Posted by Houston1
thanks for the reply. what you said is true and thats probably what i will end up doing. i was just trying to get some specs on the factory amp.
Dynamat the crap out of the doors. I did, and probably added 6db to the low end of the speakers.
<EDITED> I forgot why I began to respond in the first place. The amplifier power is just one aspect. I would investigate the sensitivity of the speakers, too. Your back speakers may be difficult to match with an aftermarket pair if the fronts sensitivity is different. You may hear the rear speakers come to life at an uneven pace with the fronts after replacement. </EDITED>
