Here are some pictures of my installation.
http://www.dfwsbr.com/crossfire/exterior/hid/
The kit I used was originally purchased for my Eclipse. It didn't fit directly in so I had to modify the tabs on the actual bulb. You are going to need to make sure the bulb fits securely with out having any angles in the housing.
DO NOT TOUCH the bulb wiht your fingers. Oil will get on the bulbs and could explode. You do not want glass fragments in the housing.
If you are unsure if anyone has touched them, use a clean paper towel and some rubbing alcohol to remove any oil from your hands.
