Old Mar 24, 2008 | 09:38 AM
distantpulse's Avatar
distantpulse
Default Re: I need your opinions...
Originally Posted by ZAHANMA
in response to one of your issues... the headlight fogging.... are you talking about a visible moisture inside the headlamp assembly, or simply a "foggy" headlight with a film on the outer plastic...
as for moisture issue i cannot say that i have a convenient and easy remedy for it, however if it is just a film on the outside of the headlamp the do in fact make a product specifically designed to renew old headlights. check autozone or napa if that is the issue.
See, thats the thing. Im not exactly sure if it's fogging on the inside or not. I would assume it is because when i wash the car it gets worse. I have used the plastX product. It cleans and polishes decent, but i still have that "cloudy" look on the top edge of the headlights.
