Old Mar 26, 2008 | 09:24 PM
cruzinquick's Avatar
cruzinquick
Default Re: 2nd times a charm, Joined the 12 Sec club tonight
It's ok to take it easy, make sure your comfortable with your car and the track before you go all out. You may want to start with just launches, then 1/8 mile runs, and work your way to 1/4 mile passes. If you get squirley with all the power your going to be putting down you may need traction control to take over. You can also launch easy and then lay into it. Remember no one here is going to chip in for a front end if you wreck your car. Also the better the 60' time the lower trap speed you will have, but your et will also be lower. If you spin more, you will notice higher trap speed. I once ran in the 12.7's at almost 112. Good luck, have fun, but most of all be safe. It's why we go to the track and not the street, but it still can be dangerous.
