Originally Posted by cruzinquick
50 degrees the next time you will be in the 12.7's easy with the conti's. Go around the water and back up to give you some room. don't go in the water. Light the conti's a bit and your ready to go. Launch around 2200 rpm or just a bit higher and you should be off to 1.90 60' times or better.
The first run (12.89) kind of caught me off guard (my first ever run) and they hadn't wet the staging area yet. The last two the water was unavoidable so I think that played into my slower times. I definitely need to work on my launch either way.
