Old Jun 28, 2004 | 06:24 AM
WesMichaels's Avatar
WesMichaels
Default
Originally Posted by Mo_Bandy
Everything have seen suggests that the ECU has to be pulled and the Eeprom removed...
The other two cars I have can be programmed through the ODBII connector, this i think is tremendously easier than soldering and desoldering chips...
aside from the programming "modification" I have the wherewithall to do the same thing myself I have the prom burners and such
So based on your answer, there is no alternatives aside from soldering and desoldering the chip...
Mo
The prom does have to be removed and reprogrammed. None of the performance chip companies are offering any chip tuning via the ODBII port.
