Old Mar 30, 2008 | 07:25 PM
R/TommyB's Avatar
R/TommyB
Default Re: Radar Detector Hard Wire - V-FAQ
All the fuses in the panel inside the drivers door are always live and will work fine.
If you are looking for a connection which is live only when the key is on follow my instruction in post #18.
Actually, I went and checked it out myself today.
Fuse #4 is not live all the time, and it is active as soon as the key is turned. Most of the other fuses are not usually live, as they are linked to lighting systems and are only active when the lights are on.
I tested out a temporary setup today (there are 3 grounded bolts behind the weatherstripping, and everything worked fine. My plan is to get a fuse tap around fuse #4 and connect to that. MY only concern is that it will all fit. I will keep you updated.
