As stated by our Mike-in-Orange, the Crossfire is a very 'tossable' car.
Having been on the track several times with mine (road courses only), I would say it has some understeer, but that can be easily fixed. (By two things, stiffer rear suspension and the
Phantom Grip for better traction distribution) These are on my list for this year.
The other upgrade I would recommend before it becomes necessary is swapping out the OEM intercooler pump for the Johnson CM30 marine pump. (IC pump failure is a commone occurance)
Lastly, if you are ever going to take the car to the track (Road Courses or Auto Cross), I would suggest upgrading the brake fluid to something like Motul 600 (which is what I run). Better pads will also be a must, I run Porterfield R4 compound at the track.
Hope that helps... good luck in your search for that SRT6!
Cheers!
