Re: Enter drydock
If you search this forum for IC Pump and Johnson, you will find that a Johnson CM30 pump is a nearly direct replacement for the OEM pump and will last much longer. This is a tip we found out from our brethren over at the MBForums.
I have already done this with mine and the IC pump had not yet failed. I just didn't want to be at the track when it did... .
Do some searches here, you can find answers to almost any question about the SRT6.
Welcome to the forum!!! The rest is below...
