Old Apr 7, 2008 | 05:54 AM
Steve Hellums's Avatar
Steve Hellums
Default Re: LET HE and Johnson pump install
Here's the finished product
There were only two things that I'm not fond of with the new HE.
1) there's no mount/support on the bottom of the HE and it can be moved/twisted back and forth.
2) you can no longer use the stock air guide that filled the space between the bumper and HE.
Ohhh, and I ended up having to switch to worm gear type clamps on the Johnson pump as it is a slightly smaller OD than the stock pump. I found that out after I filled the water/coolant and it started leaking like crazy all over my floor.
I don't see anything but red X's for pic's, but I've had the front bumper off so I know whats in there. Your #2 dis-like don't sound good, that's what really funnel's the air to the HE, do you have plans to fab up something to take it's place?
