Thread: Best ECU Flash
Old Apr 7, 2008 | 09:37 PM
Montana Crossfire's Avatar
Montana Crossfire
Default Re: Best ECU Flash
I have done quite a bit of work with inmotion in Oregon they are very customer service conscience.
I have had them do the same ECU several timess till I got the power band I was after and they did them at no additional charge.
You should have your ECU re-flashed whenever you change anything as drastic as a Crank pulley. Injectors, No. What you have stock can handle quite a bit of modification.
Mike
