Old Apr 8, 2008 | 01:34 PM
corfire's Avatar
corfire
Default Re: Flat Key Part Number?
Originally Posted by tom2112
Max, you're not listening. This is NOT a key that you cut yourself. It is NOT a blank. It is pre-cut from the same place that send the fobs, and it includes a transponder (not a transmitter - as in remote). It is a Chrysler part number, and you would order it the same way you would order a new fob, just different part number.
I don't think that such a key exists, although I have also seen references to a flat key on the forum. If it does I, want the part number also. Using the search, I have found information from a guy that took the key and transponder out of a fob, and then glued the transponder to the key. So, he made his own 'flat' key, although it isn't really flat. Here's a link to the pic:
https://www.crossfireforum.org/galler...php/photo/5452
I checked with a Mercedes dealer once and they said a flat key is available for the SLK. So, I don't see why one couldn't be made for a Crossfire. However, you need the key laser cut and transponder (not transmitter) programmed for the VIN. That's the problem. The Mercedes guy said he might be able to get a flat key to open the door, but without transponder??? So, you couldn't start the car. But, he really didn’t know. My Chrysler dealer just said it can’t be done.
