Old Jul 1, 2004 | 03:30 AM
itsveryhot's Avatar
itsveryhot
Default
SALDOUS,
TO RESPOND TO YOUR PROBLEM WITH THE POWER TO THE SILL PLATES.
YOU SHOULD CHECK THE POWER AT THE INWARD PLUG AT THE UNIT'S CONVERTER/TRANSFORMER. THIS UNIT IS LOCATED BEHIND THE PASS. SEAT UNDER THE CARPET COVER ON THE WALL OF THE DIVIDER OF PASS. COMPARTMENT/TRUNK STORAGE AREA.
PULL THE PLUG FROM THE UNIT WHEN YOU HAVE POWERED UP THE INSIDE LIGHTS AND THE SILL PLATES ARE BLACKED OUT.
THE PLUG SHOULD CONTAIN SIX OUTLET CONNECTORS. (2) ARE FOR THE POWER TO THE RIGHT SILL PLATE. (2) ARE FOR THE POWER TO THE LEFT SILL PLATE.(THESE 4 CONNECTORS SHOULD INDICATE -O-
VOLTAGE). THE LAST TWO CONNECTORS ARE THE POSITIVE AND NEGITIVE POWER OUTLETS.(RED AND BLACK WIRES THAT PICK UP THE POWER NEAR THE DASH. IF YOU INDICATE POWER AT THIS POINT, REPLACE THE TRANSFORMER/CONVERTER UNIT. CHRYSLER WILL REPLACE THIS UNIT UP TO ONE YEAR OF OWNERSHIP. THIS IS WHAT CHRYSLER DID FOR ME; REPLACING THIS UNIT FOR ME! (BAD UNIT) WILL ADVISE YOU WITH MY NEW INSTALLATION RESULTS.
