Old Apr 9, 2008 | 05:37 PM
Maxwell's Avatar
Maxwell
Default Re: Ebay Rotorworks drilled and slotted rotors?
if your going to purchase drilled rotors you want the holes to be cast in the rotor not drilled, this will prevent cracking.
If you get the slotted rotors they have a tendancy to make an annoying buzzing sound while driving.
stick with the smooth surface rotors, and run cooling hoses to the brakes and use only ceramic pads. for another $80 you can get the oem rotor cryoed for more heat resitance. should make them last a little longer
