Originally Posted by BlUEMDsrt6
I know its an HE and not the intercooler, but was just wondering if spraying the HE would work also. Thanks for the info everybody.
I'm not saying you didn't, but those sprayers are for an air-air setup.
An air-water setup is approx 14 times more efficient at transferring heat from the liquid to the HE than an air-air setup. The additional atmospheric transfer, assisted by the CO2, is only minimally aided.
IMO, you would be better off with an ice reservoir for the coolant and separating your IC system from the engine coolant.
Please be careful spraying any liquids
into the Kompressor. It is meant to be a dry setup.
