Old Apr 10, 2008 | 12:23 PM
rostija's Avatar
rostija
Default Re: Ebay Rotorworks drilled and slotted rotors?
If you are racing and have brake fade, part of your problem is with the brake fluid. Brake Fluid also takes away heat. Brake fade can happen when your old fluid heats up to it's boiling point. If it is old/original fluid...it is time to purge the stuff and get new. If your fliud is recent, then you may need to go to a higher temp (brake fluid boiling point) fluid designed for high heat racing applications. Best fluid is from Castrol but it costs around $60 per liter and needs to be replaced after a year of use.
parillaguy
