Re: Potential Answer To Cooling These Beasts?
Please be advised that the carbon dioxide coming out of the tank is cold and can immediatley destroy the heat exchanger due to freezing. Giving a blast of CO2 is about MINUS 109.3 degrees and that will freeze the antifreeze most quickly. If you want to cool it off without the cost, use a leaf blower, I used one with a water mister and it was very effective at the trackwithout all the water on the ground, tires and such. Leaf blowers are several hundred CFM as long as you want to run it and it is cheaper to refill. Woody
