Re: Horn stop working.
Originally Posted by BORICAN
My horn stopped working. I checked the fuse and it's good. What else can it be? I checked the wiring to see if it was loose but it was connected. I tried to check the current at the horn when pressed and released but nothing, no current .
Does anyone know where or what color is the main power wire coming from the steering wheel to the horn?
What fuse did you check? There are 2 fuses one is in the ecu box and one in the box on the drivers side under the hood.
