Re: Juiced...
awesome that would be great, where the nozzle should be mounted to spray and where i should put the t in the fuel line to get fuel, i have a zex wet kit gonna run a 75 shot. very easy set up i just want to make sure of where to do thes two things before i go cutting, i am just worried about where to mount the nozzle because of the maf sensoe and throttle body, but there is a ninety degree elbow before throttle body and puddling could occur if spraying into that, but yes i will def. go by your pics, you are having good luck with it?? any problems at all??
