Thread: Tvt250
Old Apr 13, 2008 | 02:55 PM
TVT_DESIGN
Guest
Posts: n/a
Default Re: Tvt250
We'll have dyno numbers posted later this week with full 6200 RPM runs and AFR.
This system will be totally reliable and extremely easy to live with on a day to day basis.
Stage 1 add ons will include: EGR block off plates (much cooler intake charge and less oil in intake stream resulting in higher effective octane of fuel), Thermostat (cooler engine pulls less timing and as a result you get more power), Upgraded plugs and wires (better idle, improved throttle response, and more power in the Upper RPMs).
This will be Stage 1+ and will net around 265 HP.
Stage 2 will include Stage 1+ and some additional power adders to bring the total up to about 280HP. Exhaust, pulleys, and lightened crank pulley will be in this pacakge.
That's about as fas as we've gotten right now.
We'll hit 300HP on the stock displacement and then take a break from this car for a little bit. I'm sure with 300HP available there will be many things to keep you occupied while we're away though.
Anthony
