Originally Posted by Iamfink2
Mike will this work on the top cowl where the wipers are to make it look clean and bring out the color like when it was new.
Yes, it does a great job of cleaning the plastic cowl cover. Don't be stingy with it though, and make good use of some microfiber applicators or those yellow foam applicator pads Meguiar's sells.
I bought my 2005 Limited Roadster new just last July and the cowl cover, windshield header and other rubber trim was just a horrid mess. #39 did a great job on all of it, but since it's a cleaner only you'll want to use a dressing of some sort as a follow up. Whether you prefer 303, Meguiar's #40 or something else is up to you, but definitely put something on it.
If you're thinking will this help on the roadster deck lid tape - no. So far I have found NOTHING that will even out the appearance of the tape strip, especially since mine sat around for two years before I bought it. What have I tried:
Meguiar's M39
Meguiar's M40
Meguiar's All Purpose Cleaner
Black Wow from showcardetailing.com
Back to Black
303
50/50 water/alcohol mix
Simple Green
Orange Blast
I can minimze the two tone look for a while, but the texture even feels different between the exposed half and the half under the roof.
