Thread: Questions
Old Apr 13, 2008 | 03:46 PM
Floaten621's Avatar
Floaten621
Default Re: Questions
Actually i am interested in the NA model. a buddy of mine from P&P tuning are going to build a custom turbo kit for the vehicle. i know that the srt6 is supercharged. But since i don't own one i don't know what a stock srt pushes through the block in the form of boost. i know the failure point of alot of stock motors. Mercedes is not one that i am familiar with.
i know its just like any other board where guys get all uptight with questions. i guess i should have been more specific.
Has anyone done a TT setup on this engine yet..
What is the stock failure point and what is safe as far as boost.
Do i need to modify the injector rail to fit bigger lbs injectors or do they make bigger ones.
What type of tuning is everyone running other then the factory PCM. cause i know dodge-mercedes can be a bear to crack.....
The software that we have can only work on ford and GM right now so i didn't know if stand alone was needed???
sorry if that was long but if you know any answers that would be great. i did find some stuff under the search, but again didn't want to spend hours searching through every little detail. Thanks again
