Re: Compression readings
According to the on-line parts manuals (Chrysler and MB) The 3.2L engine shares the same block, heads and valves - but that's about it - part numbers are different for the pistons - rods, camshafts, crankshaft...
The cylinder bore may be the same but I would guess that the piston domes, piston stroke, valves etc.. provide the difference in compression ratios.
Even if you could just "bolt on" a factory SC on the NA Crossfire - you won't have the same engine.
I don't trust the part numbers. If you change the stroke and not the bore you won't have 3.2 liters of displacement. I don't want the same motor. I want a better motor.
