Originally Posted by rcompart
I've done quite a bit of searching both on here and google but still I'm coming up empty handed. Is the Sprint Booster just for the automatics or is there any benefit to this in a manual as well?
As kindly advised by our USA based forum buddies, It seems, for some reason, my ECU didnt detect the presence of the gadget. So before giving up on it I went through the following process;
1: remove the S.B. to and confirm it as inoperative.
2: do the throttle reset proceedure, and again no difference.
3: refit the S.B. again no difference
4: do the throttle reset again with S.B. fitted: results = WOW - NEARLY SHREDDED MY REAR TYRES!
It appears that the throttle reset done with it fitted did the trick! ( but Im not sure why )
It may be a step for everyone to do this after fitting the S.B. ?
Cheers for now
Steve
