MI1XFIRE is correct. The bolt pattern needs to be 5x112. Also, the seller is has not listed the offset of the wheels. If they were 5x112 with a 35mm offset, then you probably could use them. Although the width seems a bit excessive. I'm running an 8" wide wheel in front and I'm close to max on the clearances.
Sorry dude... those would look awsome on a Crossfire.
