Old Apr 15, 2008 | 08:19 AM
Idaho's Avatar
Idaho
Default Re: Car on jacks for a week
Originally Posted by [B
bflinn[/B]]Porsche specifically recommends not to jack the car for any extended period of time as it will eventually lead to suspension to sag. Theory is that the suspension is built to support the weight of the car and not to hang freely with wheels/tires on the end of it.
bflinn,
I would agree that if you lifted the car completely off the ground it would be as bad as not using jacks at all. In CrossfireRoadster case where he has the wheels off to paint the calipers he won't have an issue, but if you are storing the car for extended periods of time like RPM, crossfirefun, crossfirefrank, and myself you do need to unload the suspension or it will sag over time. What I do for storage is put rubber mats under the wheels and then jack the car up just to the point where the suspension is sitting at about half travel or in a neutral position.
