Hi Saldous.
We should catch up some time. I hadn't thought about the receiver position, just expecting to install on the dash or something? Any better ideas? Boba where have they/you put yours?
Re the POI's it is very easy, just touch the POI menu and select the type of category you want. Looking at the Manual you have Restaurant, Petrol Station, Automotive (Garage and vehicle dealers) Transport (Bus station rail etc) Shopping, Hotels etc. You get the closest ones displayed with the mileage from your current location. If you enter one mid guidance, it will just add it to the route as a waypoint.
I was planning to put a multi disc changer in the first aid boot hole, other side to the tyre kit. Do you know if it will fit? I was also looking at this :
http://www.hitchcam.com/images/FrameCAM_Data_Sheet.pdf
but i think the UK licences plates are larger/longer than the US's. It should be modifiable though. I can't figure out how to get the cable back through to the boot space without drilling the body work which i donft really want to do. :? or put something like this between the exhaust and the chassis...
http://www.mobilevideozone.com/produ...3-D116DD416D32
