Sorry to say that buffer just isn't going to get the job done, especially with our very hard clear coat finish. I'd bet the wool pad you used put some of that marring into the paint, but you should be able to get that out with a proper DA polisher - the Porter Cable 7424 or the new Meguair's G110 - and the right pads and polishes.
I highly recommend you check out autodetailingsolutions.com, specifically Package #2 at
http://www.autodetailingsolutions.co...20Specials.htm as this will hook you up with practically everything you need to get started. But regardless which pads and chemicals you use, technique is EVERYTHING when it comes to machine polishing. At least with a DA polisher if yoiur technique is bad the worst that will happen is you'll just push the product around and not get a lot of results. You will NOT damage the paint unless you drop the machine on the car.
You might also want to check out the forums at
www.meguiarsonline.com for some detailed info on proper techniques for machine polishing.
Thanks for the info, I just picked it up because I figured it be better than my hand and hoped it would get the majority of swirls out. (WRONG) I wish I wouldn't have got all excited and grabbed a pos before I saw the link for the porter cable at 99$. Anybody want a free giant toe nail buffer?
