Old Apr 18, 2008 | 10:27 PM
imabenz's Avatar
imabenz
Default Re: Stuck in 1st Gear
It very well could be your battery especially if the battery is at least 3 years old.
I've read posts about dead batteries, but have yet to see one about an alternator failure.
It may also be your alternator, serpentine belt, corroded/loose battery cables, or loose connections at the alternator. Any of these would prevent your alternator from charging your battery.
If you cant have your battery and altenator tested, replace the battery. If the battery drains again in a matter of days, then it wasn't the battery. This applies well to older batteries that are approaching the end of their life cycle anyway. Even if its not the battery, you were going to need a new battery soon anyway.
Good Luck
