Old Apr 19, 2008 | 09:45 AM
mrphotoman's Avatar
mrphotoman
Default Re: which gas do you use for your Crossfire?
Originally Posted by SRT6 Dan
only 91or higher ! Why would you want 98 if it runs good on 91-93 does it run any better on 98 ?
it is safer when running the car on the track. When you are running it hard, the temps are hotter and the chance for detonation is higher it is better to run a little higher octane fuel to prevent the car from detonating and pulling timing. If the car does not pull timing then that equals more consistent times at the track. If you raise boost it is better/much safer to run a higher octane at the track also. The Klotz also raises the oxygen level in the fuel as well which CAN mean as much as 8% more hp. Yes it is better to run a higher octane for a forced induction or high compression motor at the track.
