Old Apr 21, 2008 | 04:50 PM
Guest
Posts: n/a
Default Re: Compression readings
Originally Posted by almecum
Hi I had asked about a comparision between engines and the specs for both are listed in the post.
https://www.crossfireforum.org/forum...ad.php?t=22544
After reading the above mentioned post I found that the compression reads 100 psi for the Limited and SRT6. If this was true, than they would have identical compression ratios.
