Old Apr 23, 2008 | 07:42 AM
Opticon's Avatar
Opticon
Default Re: How To: Building a Short Ram Intake for about $150 (for Your N/A)
Originally Posted by x justin
As far as the temperature thing goes, the OEM setup puts the entire thing right on top of the engine. It acts like a stove just sitting there cooking the air coming in. The stock airbox gets extremly hot. While you can't do anything to lower the under hood temps, you're still going with a way less restrictive setup, and the piping is away from the engine, so there must be gains.
Define "restriction". These cars don't have airflow problems if that's what you meant. The factory supplied more than enough CFM to keep the NA happy. And despite baking the airbox and filter (which you are still doing with your short ram) the OE pulls ambient air from behind the grill.
Get that filter out into cool air and insulate that intake piping. Then you will be gaining something (assuming there is room for adaptation in the Crossfire's VERY lean OE fuel setup).
