Re: mix-matched tires
I found if you roll up a 5" wide strip of bath towel around the oil filter stem instead of using the OE fleece filters, you can greatly reduce the cost of an oil change. Used cooking oil is a fair bit cheaper than synthetic 0w-40 as well.
Maybe I should start a DIY post.
