Re: Brandons Pvc solution
WARNING
the most important detail left out.
it should also be noted that all the Home Depot/Lowes water separators have a check valve in the plastic drain valve. you cannot use these under vacuum unless you put a plastic vacuum cap over the drainage nipple, otherwise it will not function correctly, it will just become a source of a vacuum leak!
