Re: The big fancy crossfire cover under the hood...
disconnect the two air hose tubes at the front of the engine compartment (they slide into one another) and pull hard upward on the back edge (center area) of the cover to remove it. it is held on by rubber grommets and clips. the 2 filters are located beneath the cover and require a torx bit to remove them.
cheers!
