Originally Posted by splinter
if you can find an adjustable regulator that will boost the fuel pressure then TVT can probably cut the cost down to $700-$800 the expensive part is the new injectors, but then again the mercedes benz already have upgraded injectors over the stock Crossfire which is why we run leaner than slk320's. so your price will probably be much lower since all you need is TVT's ecu map and CAI
