Originally Posted by MAYAman
When you modify the airbox you also increase the tubing and inlet behind the grill to the airbox right? I looked at it yesterday and the inlet into the tubes is TINY TINY TINY.
I removed the wire mesh inlet screen fron the airbox, its easy, just cut it with wire dikes, and anything imbedded in the plastic can be pulled out with needle nose pliers.
