Old Apr 30, 2008 | 08:20 AM
  #389 (permalink)
Crossfire Trail's Avatar
Crossfire Trail
Default Re: Newport Ri Cruise
Jen, I can mirror Bob's remarks. A tune, as I mentioned before, will not void your warranty.
I had a problem during the Newport run as well. My transmission was out of whack...really out. It had started slowly with a rumble like going over a rumble strip in the road, It progressed to every time I drove the car especially in 1st to 3rd and downshifting in automatic, it would bind, I started using my auto stick more and it seemed to correct the problem. In Newport, with all the stop and go, it acted up again, I had already made an appointment for Monday so I just tried to drive slowly and not put it through it's paces. On Monday I drove it to the Dealer and took out a Charger as a rental (all covered under my 7 year 70'000. mile warranty) they called yesterday and said that it was the Transmission Control Module (part #05097773A$DGU/ 05127296A$-DGU,DED) This just so happens to be a TSB on my particular car.
It sould be fixed today, I miss my baby and this 07 Charger is really a big pain. I don't like it at all. Gas guzzler too.
Good luck with your ECU. Did you get the tune? Perhaps TVT should be called and made aware. Sometimes things can happen that you don't expect. Good luck!!!
Rick
