Old Apr 30, 2008 | 11:42 AM
TVT_DESIGN
Guest
Posts: n/a
Default Re: NA performance list
Originally Posted by Hugo
Lets add to TVT List:
Cold Air Intakes +8HP
Custom made Free flow exhaust 3" 20HP
ECU Tune (POWERCHIP Custom 100 octane) plus 7 point octane boost to 107 points 35HP Minimum
Injectors (allows for more HP) 2-3HP
Ignition Wires (+5HP) Dont know bigger spark bigger bang
NGK Spark Plugs (better idle, possible HP increase)
Underdrive Pulleys +6HP
Modified Airbox/Hi Flow Filters +10-12HP
Camshafts +15-20 but expensive
TOTAL N/A Standard here in Australia 212HP
Total mods above 104HP total
316HP at the crank
Nuff said
Just to clarify your HP quotes here: an exhaust will add 12RWHP at best with a properly built dual exhaust, cat backs normally gain around 5. The ECU tune wil not you no more then 18RWHP without larger injectors, regardless of the octane you use. You can't make power without the fuel. Just an example with the injectors added to the CAI and ECU tune we picked 29RWHP, from just adding injectors. That doesn't mean injectors added to a stock motor will add 29HP, it's a ll about harmony.
With a spot on tune and the stock intake and exhaust manifolds, 300HP will be extremely tough to get, but doable. A new manifold and headers will really wake this engine up.
