Re: Sprint Booster - I don't get it
FYI ... The SB has nothing to do with being the same as just pressing the pedal twice as far, pressing the pedal further has nothing to do with inherent drive by wire throttle lag . Sorry but simply pressing the pedal harder to achieve WOT will not change the initial lag no matter if it is from a start or throttle up while at speed. Throttle Lag is a delay in throttle response from the time you touch the pedal until the car responds to the command.
By the way it no it does not increase HP nor can it be measured by a DYNO. For more info just do a search and you will find TONS if info on this site.
