Originally Posted by mrphotoman
it sort of vague where it says "move passenger side horn to drivers side with new bracket.
where do you bolt the new bracket to? if you bolt it on top of the drivers side horn bracket the wires are too short and the 2nd bolt is too short
also, the 90 degree rubber elbow will not go over the throttle body. i tried a little liquid soap and it still does not fit.
Replace the driver side horn bracket with the new one. If you undo the grommet/horn wire, it will reach over to the new bracket hole.
The rubber elbow takes some time to get right. It will fit, but you might have to wrestle with it for a little while. Try doing the bottom first, then the top.
Hope that helps.
