Re: need help on needswing intake intsall
Mrphotoman,
I think the elbow may be slipping off the intake due to the soap lube you had used.
I got mine on with no lube with the assistance of a screwdriver like a shoehorn working from the bottom upward.
Then I tightened the clamp as hard as it would go using a nut driver instead of a screwdriver.
It is on tight and not moving at all.
For others here.....
As far as the upper plastic rivet on the plastic OEM air duct (passenger side)
I found by reaching behind with a center punch and lining it up with the back of that plastic rivet just one punch with a hammer will pop that sucker right out with no problem.
Then just a little twisting etc the housing will come out.
