Originally Posted by macavelli24
The rear wheels and tires actually ended being almost the same total height because of the smaller side wall on the bigger wheel. As far as the speedometer, I thought it was off but when I check it agianst my GPS is seems to be spot on. And I will try to get pictures up as soon as I can, but I'll tell you right now I think the wheel gap is too big and I'm going to lower it when I get a chance.
I dont think it would be right, just because 255/35/19 is stock and you went wider and taller in the rim so you should bhe almost 2" taller unslee you are running 275/30/20's then you should be good.
Justin
