Old May 3, 2008 | 09:16 AM
70GT6's Avatar
70GT6
Default Re: Bought K&N air filters...now need find instructions...
*** IF LIKE SRT***
Pull up on each side and the front, one place at a time. There are clips in rubber mounts that will release. Lift off cover.
You then will have to use a torx driver to remove the screws from each air filter cover. (6 or 8 each) I did not have to disconnect any hoses.
Just lift the covers enough to remove/replace the filters. (DO NOT forget to install the foam spacers included with the K&Ns. They stick to the underside of the filter covers, in the "groove")
