Originally Posted by badseed1
Does anybody here know where I can find a pinout diagram of the Crossfire's yaw sensor (or Dynamic Sensor Supply, I think that's the DC term)?
Simply, does anyone know which wire is the positive power supply out of the 5 wires? The colors are: solid brown, green with yellow, solid green, solid white, red with green.
I'm going to cut the power wire and fab up a switch so I can mount it in the interior for switching the yaw sensor on and off easily.
Out of the 5 choices you have you can automatically eliminate the solid brown(brown=ground on euro cars)................so you can go from there with a test light. Test ignition off each wire and see if they light up..........then test ignition ON and see what ligthts up.
