Originally Posted by 70GT6
*** IF LIKE SRT***
Pull up on each side and the front, one place at a time. There are clips in rubber mounts that will release. Lift off cover.
You then will have to use a torx driver to remove the screws from each air filter cover. (6 or 8 each) I did not have to disconnect any hoses.
Just lift the covers enough to remove/replace the filters. (DO NOT forget to install the foam spacers included with the K&Ns. They stick to the underside of the filter covers, in the "groove")
SRT must be considerably different than my roadster limited. Although most of the removal of the intake cover is the same. I found if I just lift the front two clips off the rubber mounts then go to the back and lift those that whole assembly including the two pipes that come in on the sides comes off in one piece. It is pretty heavy and you are bent way over to get at it but it all comes right out. Flip it over on a piece of carpet and install new filters. I found no foam pieces in the K&N box just the filter. Reassembly is quite intuitive too and easy...popeye
