Old May 4, 2008 | 10:39 AM
cruzinquick's Avatar
cruzinquick
Default Re: Rmr Midnight Drags!!!
Heres a cool way to see what you would run at some of the other tracks.
go to racefan.com and search for the tracks section. I think it's forum member distantpulse that runs at ATCO raceway. Get the track elevation. Then go to weather.com or something similar. You can go right down to the time of day and get the humidity, pressure, and temperature. Then hit modulardepot.com and click resources. It has all the different calculators, but the sea level calculator works best. I bet you might be a decent 14 sec at his track. The elevation is only 33 ft. On some of those tracks the calculators will actually add time to their et's because of the negative DA. sorry for the new terms if your not familiar with them, but it will level the playing field to see what you really are running.
Cruzinquick
