for the gtec to read properly you have to launch without spinning the tires, once the tires light up the gtec results go out the window
I know that's correct, that's one reason I alway's launch with the TC on. I have made a couple runs with the TC off with a lot of spinning and the results were mid 11's in the high 120's. I knew that couldn't be right, but it is very consistant with the TC on. I've also had it fault out because of the TC kicking in so bad.
